everything tightly with plastic cling wrap... the packing stuff, not Saran Wrap. Heads were wrapped separately from the block. Clean everything up as best you can. I'd throw in a couple of dessicant packages to retain any moisture. Keep the girdle on. Impact will be fine to remove head bolts, careful of the cams, though.
I assume you'll have work done to the engine before re-assembly?
Regards,
WARNING! Forum posts are likely to contain traces of irony. If you believe you may be suffering from an irony deficiency please consult your physician.
My Zs are hybrid vehicles, they run on gasoline and money
I'm off to wax mine and go for a drive now. - BigTDogg (MA) 07:17:08 07/17/09
times change, people change, but the Z32 still kicks ass. - apudapus 16:46:02 06/15/07
I was more wondering how you set your climate control to 22* lol, it would be that fastest freezer on wheels! - Briscoe'sZ32 (NJ) 23:15:44 02/05/07
You have *got* to be getting a cut from B&B :D - SeedyROM 15:24:29 08/16/06 What do you think B&B stands for? - YugoBernie (NoVA) 15:57:09 08/16/06
